ArcGIS Pro 2.8, Civil 3D 2020
I added a Civil 3D DWG to a fresh, empty Scene in ArcGIS Pro. The coordinate system in C3D was defined (NAD83 HARN SP CA ZnIII US_ft), but Pro did not recognize this coordinate system. I had to define the projection for one of MANY layers brought in from the DWG, but luckily all the other layers updated in sync to the correct XY location after defining the first one.
However, the elevation units do not update automatically. I know that the z-values are in US survey feet referenced to NAVD88. I just recently learned that vertical datums cannot be defined in a Civil 3D 2020 DWG - you have to get this info from the engineer or surveyor. The z values are unitless. All of the MANY CAD layers have their elevations units defaulted to meters in ArcGIS Pro 2.8. I'm guessing this is because Pro adds the default base ground elevation surface to new scenes which is in meters (WGS84), and undefined layers get the scene coordinate system applied (?).
Now I have to manually change the elevation units property for each of the MANY DWG layers from meters to US_Feet.
There has got to be a better way, right? Either a setting in C3D, or a different import process? Maybe create the scene first and update the scene elevation unit properties to US_feet first before importing the DWG? Or maybe there is a way to bulk update the elevation units for all the layers in a scene?
