Does File Geodatabase support SQL Join Update Query while using DatabaseClient.ExecuteStatement in ArcGIS Pro SDK. If so can you please send me the syntax for File Geodatabase.
Similar post has been as created for ArcObjects: https://community.esri.com/t5/data-management-questions/update-a-file-geodatabase-using-an-sql-join/td-p/506921
Joins are read-only. You can edit the underlying base table that makes a join and join reflects data changes that are made to the base tables. Code snippets and additional info are on Join, Snippets.
