I am trying to figure out How to get the GENERATE_ID value through SQL Server. Please anyone knows how to get it or implemented such scenario.
Please help. Thanks!
I'm sure you've seen this, but just in case..... It looks like you would add a row to the "Generate ID" table:
https://solutions.arcgis.com/shared/help/attribute-assistant/workflows/configure-generate-id-table/
If attribute assistant is set up on an SQL database that probably runs Create Sequence in your SQL GDB
https://docs.microsoft.com/en-us/sql/t-sql/statements/create-sequence-transact-sql?view=sql-server-ver15#:~:text=A%20sequence%20is%20a%20user,restart%20(cycle)%20when%20exhausted.
Thank you Kim,
Yes. I have checked the links you have shared. But I want to use the existing SEQNAME in SQL queries inserts.
Why because there should not be clash between ID generated by SQL and ArcMap Attribute Asst.
