it seems as if in version 4.22 neither the parameter layerIds is accepted in the IdentifyParameters nor the layerOption "visible" is updated.Example:I want results from "Vorhaben", layerID 405https://ims.kiel.de/extern/apps/Vorlage_js4/samples/identify422.html
This still works with version 4.21.Example:I want results from "Vorhaben", layerID 405https://ims.kiel.de/extern/apps/Vorlage_js4/samples/identify421.html
MapImageServer "MIL" with- Layer "Vorhaben": LayerId: 405, visible: 0- Layer "Wohnungsbau-Vorhaben": LayerId: 395, visible: 1
Script:// toggle Visibility[...]// set IdentifyParameters[...]// I want results from "Vorhaben"identifyParams.layerIds = [405];identifyParams.layerOption = "visible";[...]
view onClick-> I always (!) get results from layer 395 and never (!) from layer 405
Hi @AndreaKittler, this is a known issue that will be fixed at the next release (4.23). It should also be ready to test on next: https://github.com/Esri/feedback-js-api-next.
Here's a potential workaround: https://community.esri.com/t5/arcgis-api-for-javascript-questions/identify-not-honoring-layerids-supplied-to/m-p/1137516#M76101
Thank you very much, I didn't found it...
