Hello!
I'm using a calculation to pull text from a text input field into a note field within a survey built using Survey123 Connect. Is there any way to format the note field to increase and bold the text size? Any help is appreciated.
Rather than using the calculate column, you can add HTML tags directly into the label column:
Example output:
Would that work for what you need to do?
This is perfect! Thanks for the help.
