Arcmap 10.8.1 moving to ArcGISPro soon
Choosing the best coordinate systems. I would really appreciate any feedback.
I have been away from gis for 12 years, butting getting reoriented and have to do for myself now, where previously Esri and IT support handled. So I have received traiing two decades ago, but have not practiced much of it.
I am setting up a project that I will be doing for years to come, and I want to set it all up the best way.
In getting reoriented, I built my GDB on the fly and learned as I went. I am at the point now to build a new mapping project to support my work with the features in my GDB.
I will be working on the USA east coast between Longitudes -79 - -81 and from Southern New York south though South Carolina and Geogia.
From studying about coordinate systems and how to choose, I find the following.
Choose the Geographical Coordinate System designed for the area I am working in for the best accuracy. (I am looking for actual on the ground accuracy. To plot something and find it at that position, more so than how it is projected, yet also want to project it as well as possible)
Ensure all feature layers I am creating use the same GCS.
Supporting feature layers GCS should be converted to align with my GCS. These include streets, streams and contours primarily but include others depending on what I can find available in each county or area.
The Map Data Frame should also use the same GCS. ??Or should it?
What I currently use for the features that I create;
Projected Coordinate System NAD_1983_StatePlane_North_Carolina_FIPS_3200_Feet. I think I can give you some idea of why I chose that early on, but just note the term "early on". I am trying learn as effectively as I can.
I am thinking what I should use for the extents of my work is Geographical Coordinate System Nad 83. But which version? 2011, CORS96, FBN, Harn or Harn corrected, NSRS
Is my thinking along the right lines?
Have I interpreting correctly, all I have read, heard and learned?
