I've searched the forums but I can't find any python examples to change field order for layers in the ArcGIS Desktop 10.6 Table of Contents. Is there another way to automate this process?
I'm sorry, I guess I got my wires crossed when I read "...order for layers in the ArcGIS Desktop 10.6 Table of Contents". Now I understand what you really would like to do. I just googled 'arcpy reorder fields'. Give that a shot: there are several returns.
Hi Joe,
I looked at the links and I not quite sure if those links are able to rearrange fields in the layer properties. I am importing several FC layers into a fresh map document and I was hoping to change the attribute field order in which they will appear. I know we can change them manually but I was hoping there would be a way in python to rearrange the field order and save the map document, similar to importing FC layers and saving. I'll provide the code and image below.
<SPAN class="keyword token">import</SPAN> os <SPAN class="keyword token">import</SPAN> arcpy <SPAN class="comment token"># if outside ArcMap</SPAN> <SPAN class="comment token"># inside ArcMap, use "CURRENT" for document name</SPAN> mxd <SPAN class="operator token">=</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>mapping<SPAN class="punctuation token">.</SPAN>MapDocument<SPAN class="punctuation token">(</SPAN>r<SPAN class="string token">"C:\Users\jnmiller\Desktop\Rebuild Map py Scripts\Untitled.mxd"</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="comment token"># Input Variables</SPAN> <SPAN class="comment token">#</SPAN> path <SPAN class="operator token">=</SPAN> r<SPAN class="string token">"C:\Users\jnmiller\AppData\Roaming\ESRI\Desktop10.6\ArcCatalog\SDE.sde"</SPAN> <SPAN class="comment token"># path source w/layers</SPAN> df <SPAN class="operator token">=</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>mapping<SPAN class="punctuation token">.</SPAN>ListDataFrames<SPAN class="punctuation token">(</SPAN>mxd<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"*"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN> <SPAN class="comment token"># Add layer to TOC</SPAN> <SPAN class="comment token">#</SPAN> fullPath <SPAN class="operator token">=</SPAN> os<SPAN class="punctuation token">.</SPAN>path<SPAN class="punctuation token">.</SPAN>join<SPAN class="punctuation token">(</SPAN>path<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"ProposedMainlineProjects\ProposedMainlineProjects"</SPAN><SPAN class="punctuation token">)</SPAN> addLayer <SPAN class="operator token">=</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>mapping<SPAN class="punctuation token">.</SPAN>Layer<SPAN class="punctuation token">(</SPAN>fullPath<SPAN class="punctuation token">)</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>mapping<SPAN class="punctuation token">.</SPAN>AddLayer<SPAN class="punctuation token">(</SPAN>df<SPAN class="punctuation token">,</SPAN> addLayer<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"BOTTOM"</SPAN><SPAN class="punctuation token">)</SPAN> fullPath <SPAN class="operator token">=</SPAN> os<SPAN class="punctuation token">.</SPAN>path<SPAN class="punctuation token">.</SPAN>join<SPAN class="punctuation token">(</SPAN>path<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"P_PipeSystem\P_Meters"</SPAN><SPAN class="punctuation token">)</SPAN> addLayer <SPAN class="operator token">=</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>mapping<SPAN class="punctuation token">.</SPAN>Layer<SPAN class="punctuation token">(</SPAN>fullPath<SPAN class="punctuation token">)</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>mapping<SPAN class="punctuation token">.</SPAN>AddLayer<SPAN class="punctuation token">(</SPAN>df<SPAN class="punctuation token">,</SPAN> addLayer<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"BOTTOM"</SPAN><SPAN class="punctuation token">)</SPAN> fullPath <SPAN class="operator token">=</SPAN> os<SPAN class="punctuation token">.</SPAN>path<SPAN class="punctuation token">.</SPAN>join<SPAN class="punctuation token">(</SPAN>path<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"P_PipeSystem\P_MeterSetting"</SPAN><SPAN class="punctuation token">)</SPAN> addLayer <SPAN class="operator token">=</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>mapping<SPAN class="punctuation token">.</SPAN>Layer<SPAN class="punctuation token">(</SPAN>fullPath<SPAN class="punctuation token">)</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>mapping<SPAN class="punctuation token">.</SPAN>AddLayer<SPAN class="punctuation token">(</SPAN>df<SPAN class="punctuation token">,</SPAN> addLayer<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"BOTTOM"</SPAN><SPAN class="punctuation token">)</SPAN> fullPath <SPAN class="operator token">=</SPAN> os<SPAN class="punctuation token">.</SPAN>path<SPAN class="punctuation token">.</SPAN>join<SPAN class="punctuation token">(</SPAN>path<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"P_PipeSystem\P_Regulator"</SPAN><SPAN class="punctuation token">)</SPAN> addLayer <SPAN class="operator token">=</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>mapping<SPAN class="punctuation token">.</SPAN>Layer<SPAN class="punctuation token">(</SPAN>fullPath<SPAN class="punctuation token">)</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>mapping<SPAN class="punctuation token">.</SPAN>AddLayer<SPAN class="punctuation token">(</SPAN>df<SPAN class="punctuation token">,</SPAN> addLayer<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"BOTTOM"</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="comment token"># Set Visable = False</SPAN> <SPAN class="comment token">#</SPAN> <SPAN class="keyword token">for</SPAN> lyr <SPAN class="keyword token">in</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>mapping<SPAN class="punctuation token">.</SPAN>ListLayers<SPAN class="punctuation token">(</SPAN>mxd<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">print</SPAN> lyr<SPAN class="punctuation token">.</SPAN>name lyr<SPAN class="punctuation token">.</SPAN>visible <SPAN class="operator token">=</SPAN> <SPAN class="token boolean">False</SPAN> mxd<SPAN class="punctuation token">.</SPAN>save<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="keyword token">del</SPAN> mxd<SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
You'll probably need to take a look here to begin with: MoveLayer—Help | ArcGIS Desktop
While your at it, get familiar with: MapDocument—Help | ArcGIS Desktop & ListLayers—Help | ArcGIS Desktop
