ArcMap has a tool that is really useful for measuring angles in the COGO Report tool. Perhaps ArcGIS Pro could bring this in.
The Measure tool has an option to Measure Angle. Will this work?
https://pro.arcgis.com/en/pro-app/latest/help/mapping/navigation/measure.htm
After internal discussion with others on Esri staff ( @Scott_Harris @JenniferCadkin ) we may need some more information. However, based on what you’ve indicated so far we think that you are using the “Vary symbology by attribute” property to rotate point symbols. Is that correct?
Going with this, we put together a mini test workflow to rotate an Arrow point symbol to be oriented along the same direction as existing features. This should help to show the relationship between the measure tool’s direction units and values, and the point symbol's Rotation style.
The test workflow is as follows:
Please provide more information on your requirement and if @TimHodson response is helpful for your case.
@kyonkers_NDOT3 Closing this out until we can get some clarification. Please provide more information on your requirement, and let us know if @TimHodson's response is helpful for your case.
Sign in to post, follow content, and more. New here? Register for free.
