Hi, I want to access a local .gdb folder from the java runtime API. Is it possible to do it directly, if no then what is to be done? I'm using the below code to access the GDB file(folder). I also tried putting the GDB into a zip file but the result was same:
File geodatabaseFile = new File("C:\\Users\\gaura\\Desktop\\GeoDBSamples\\Delemont_ele" +
".gdb");
Geodatabase geodatabase = new Geodatabase(geodatabaseFile.getAbsolutePath());
geodatabase.loadAsync();
System.out.println(geodatabase.getInternal().getLoadStatus().name());
geodatabase.addDoneLoadingListener(() -> {
System.out.println("Loading GDB...");
while (geodatabase.getLoadStatus() != LoadStatus.LOADED) {
if (geodatabase.getLoadStatus() == LoadStatus.FAILED_TO_LOAD || geodatabase.getLoadStatus() == LoadStatus.NOT_LOADED) {
break;
System.out.println("GDB Loading Status: " + geodatabase.getLoadStatus());
if (null != geodatabase.getLoadError()) {
System.out.println("GDB Load Error Cause: " + geodatabase.getLoadError().getMessage());
if (geodatabase.getLoadStatus() == LoadStatus.LOADED) {
var tables = geodatabase.getGeodatabaseAnnotationTables();
for (GeodatabaseFeatureTable gdbFT : tables) {
gdbFT.addDoneLoadingListener(() -> {
System.out.println("Loading GeoDB FT...");
while (gdbFT.getLoadStatus() != LoadStatus.LOADED) {
if (gdbFT.getLoadStatus() == LoadStatus.FAILED_TO_LOAD || gdbFT.getLoadStatus() == LoadStatus.NOT_LOADED) {
break;
System.out.println("GDB FT Load Status: " + gdbFT.getLoadStatus());
if (gdbFT.getLoadStatus() == LoadStatus.LOADED) {
System.out.println("Fields GDB FT: " + gdbFT.getFields());
System.out.println("Geometry Type GDB FT : " + gdbFT.getGeometryType());
} Console Output:
Loading GDB...
GDB Loading Status: FAILED_TO_LOAD
GDB Load Error Cause: No data.
