If I change the symbology of a layer in a layout, the TOC keeps jumping to the beginning or end (top or bottom), so that I keep having to scroll down. It would be great if it didn't do that; it doesn't in a map, just the layout.
I do not see this behavior when changing symbology in a layout in ArcGIS Pro 2.9.
If there are reproducible steps, this is probably a better candidate for a bug rather than an idea. If you are able to share reproducible steps, please do and I'll try.
This was a problem in older versions of Pro, but was fixed in more recent upgrades. Starting around 2.7 or 2.8 you shouldn't see this behavior. What version are you using?
I am using 2.8, so it shouldn't occur here?
I tried to list step-by-step what is happening but kept getting lots of different results - jumping to random feature classes, to the top or bottom, nothing happening. This is the second time today that something in Pro is not working as it should, so I might just put it down as a problem or bug on my end.
I am not sure how to provide reproducible steps, since I can't provide the data or share a video of it happening due to data privacy issues.
Sorry to have wasted your time, I can't explain these random malfunctions today!
It wasn't a waste, it's always good to double check these things. I'm marking this as closed for now, if you still run into issues please let us know or reach out to tech support.
Sign in to post, follow content, and more. New here? Register for free.
