Will there be a UNtools for Pro 2.9? I see 2.8.2 from inside of Pro and Add Packages. What is the process to get the 2.9 from Conda\Esri repository? (Untools :: Anaconda.org)
They were shared on anaconda 18 days ago. If they are not visible in the python backstage, try installing them through the python command prompt.
Click Start - Python Command Prompt
Type the following "conda install -c esri untools"
This should install the 2.9.0 version.
After a refresh the 2.8.2 disappears as well.
For me UNtools 2.9 was available when I installed Pro 2.9.
or to have a look-see at what else will happen during an install, here is the conda route... --dry-run is always a good idea at first, remove it if you are satisfied
Correct!
Thanks @MikeMillerGIS
Just installed a fresh version of 2.9.6 to test in the older version of Pro and was only having untools 2.8.0 or older as an option.
Running the above command listed what packages needed to be updated/downgraded/installed. Worked like a charm thanks.
