Hi all, I'm using the Version 3.x is Esri's legacy JavaScript API, and based on this page https://support.esri.com/en/products/developers/web-apis/arcgis-api-for-javascript/3-37#deprecation/technicalarticle?id=000026486, it will became deprecated and discontinued after July 2022.
Will the version 3.xyz still be working after "retired" date or I have to migrate it to version 4.xyz to make it working ?
Hi @MuhammadAlza, I'm not sure what you mean by the "widget".
The 3x version of the ArcGIS API for JavaScript will continue to work, you can continue to use it, but once each version of the API is retired, there will no longer be official support from Esri.
For the Web Optimizer, you can no longer use it to create custom builds, but existing custom builds will continue to be hosted until July 2022.
Hi @Noah-Sager , is the "retired" mean the widget can not be used anymore, or I still can use it but, there is no more support for the version ?
Hi @MuhammadAlza, that article is specific to the Web Optimizer, which will be retired in July 2022.
https://developers.arcgis.com/javascript/3/jshelp/intro_accessapi.html#web-optimizer
If you look at the Product Support page, you can see the lifecycle for each version of the ArcGIS API for JavaScript (both 3x and 4x): https://support.esri.com/en/Products/Developers/web-apis/arcgis-api-for-javascript/3-38#product-support
However, we do recommend migrating to 4x sooner rather than later, as the majority of the development work occurs there.
https://developers.arcgis.com/javascript/latest/migrating/
