I've created a feature layer using the Add Data > XY Point Data. I imported a table from excel containing latitudes and longitudes written as decimal degrees which plotted perfectly. However, I would like to add more XY Point Data to the Attribute Table. Every time I have either copy and pasted data or entered it manually I can see the data input in the table but it does not populate as a point on the map. I can even create a pop-up displaying the data but I can't flash or zoom to it so the point was never plotted.
Do I need to run a separate XY Point Data tool every time I want to add XY Point Data? Do I just join the tables at the end?
Thank you for your advice!
