I want to obtain a new Point (geodetic) by adding x and y offset (in meters) to another Point. Is there any class or function to do that like in the case of GeodeticDistanceResult?
// Define initial point. Point initialPoint(7.65851, 45.97661, SpatialReference::wgs84()); // Apply 1000m offset in the y-direction (i.e. azimuth = 0 deg). QList<Point> initialPointList{initialPoint}; QList<Point> yOffsetPoint = GeometryEngine::moveGeodetic(initialPointList, 1000, LinearUnit::meters(), 0.0f, AngularUnit::degrees(), GeodeticCurveType::GreatElliptic); // Apply 500m offset in the x-direction (i.e. azimuth = 90 deg). QList<Point> offsetPointList = GeometryEngine::moveGeodetic(yOffsetPoint, 500, LinearUnit::meters(), 90.0f, AngularUnit::degrees(), GeodeticCurveType::GreatElliptic); // Convert offsetPointList from QList<Point> to Point. Point offsetPoint = offsetPointList.at(0);
Thank you very much @AndrewBladon ! I guess I have overlooked this method of GeometryEngine.
Could you give me an example using this method with Qml? I want to define a function that enables a point to be shifted 2km to the north. But the return value of the function is a empty list.
function addNewPoint() {var refPointList = [];var refPoint = ArcGISRuntimeEnvironment.createObject("Point", {x: centerX,y: centerY,spatialReference: viewPointCenter.spatialReference});refPointList.push(refPoint);console.log(refPointList);var newPointList = GeometryEngine.moveGeodetic(refPointList, 2, linearUnitKm,0, angularUnit, Enums.GeodeticCurveTypeGeodesic);console.log("newPointList=",newPointList);polylineBuilderAddNewPoint.addPoint(newPointList[0]);var graphic = ArcGISRuntimeEnvironment.createObject("Graphic", {geometry: polylineBuilderAddNewPoint.geometry,});graphicsOverlayAddNewPoint.graphics.append(graphic);}
Here is some sample code I put together that moves the point and displays a graphic at the new point
ApplicationWindow { id: appWindow width: 800 height: 600 title: "Untitled172" // add a mapView component MapView { id: mv anchors.fill: parent // set focus to enable keyboard navigation focus: true // add a map to the mapview Map { // add the ArcGISStreets basemap to the map initBasemapStyle: Enums.BasemapStyleArcGISStreets initialViewpoint: ViewpointExtent { extent: Envelope { id: env json: {"spatialReference":{"latestWkid":3857,"wkid":102100},"xmax":-13013797.089479687,"xmin":-13034963.75614633,"ymax":4036739.5261344,"ymin":4020864.5261344174} } } } GraphicsOverlay { id: graphicsOverlayAddNewPoint Graphic { geometry: Point { x: -117 y: 34 spatialReference: SpatialReference {wkid: 4326} } symbol: SimpleMarkerSymbol { color: "red" } } } Component.onCompleted: { movePoint() } function movePoint() { var refPointList = []; var refPoint = ArcGISRuntimeEnvironment.createObject("Point", { x: -117, y: 34, spatialReference: Factory.SpatialReference.createWgs84()}); refPointList.push(refPoint); var linearUnit = ArcGISRuntimeEnvironment.createObject("LinearUnit", {linearUnitId: Enums.LinearUnitIdKilometers}); var angularUnit = ArcGISRuntimeEnvironment.createObject("AngularUnit", {angularUnitId: Enums.AngularUnitIdDegrees}); var movedPoints = GeometryEngine.moveGeodetic(refPointList, 2, linearUnit, 0, angularUnit, Enums.GeodeticCurveTypeGeodesic); var graphic = ArcGISRuntimeEnvironment.createObject("Graphic", { geometry: movedPoints[0], symbol: ArcGISRuntimeEnvironment.createObject("SimpleMarkerSymbol", {color: "purple"}) }); graphicsOverlayAddNewPoint.graphics.append(graphic); } } }
Thank you very much!
