How to add thousands separator in Survey123? I used "thousands-sep" in the appearance column. On Survey123 Connect it works, but when I publish it doesn't work. Attached are 2 images of the problem, one in survey123 Connect and another from the published form.
Hi @Anonymous User,
The thousand-sep appearance is currently only supported in Connect and the field app, it is not supported in the web app. Looking at your screenshots, it appears you are trying to use the survey in the web app.
We have an issue in our backlog to support this in the future, for now we will add a note to the documentation, to say it is not supported in the web app.
https://doc.arcgis.com/en/survey123/desktop/create-surveys/xlsformsappearance.htm#ESRI_SECTION1_7A95781D08F14CA19D7171484A99989A
Regards,
Phil.
Thanks for the answer. Yes I am using the web app. Is there another option to add the thousands separator in the web app?
The thousands separator in the web app is currently controlled by the locale of survey, the locale of the signed in user, or the locale of the browser/device.
What locale are you using? Do you see different outcome if you use different locales?
I'm from Brazil. The form will be public and will be used by city halls of the State of Paraná
