Can we have the "Only show classes from this heading" feature that was available in ArcMap back?
Currently in Pro, I need to go to the More menu, to turn off the All other values, or go to symbology and remove there manually, but what about a setting in the legend properties to turn this capability off, I want this capability to be more intuitive.
I suppose for the time you could copy the layer. On the original layer remove <all other values> so it only displays the classes you would like to see. On the second layer include all the other values. Then you could exclude this second layer from the legend?
It seems like a tacky workaround but it might work?
I really miss this feature too! I know there are workarounds but this was much more elegant!
I really miss this feature. It would be nice to control either in the Format Legend Item or in the layer's Symbology. My utilities show as variations of colored lines (e.g. larger pipes shown with larger lines, forced mains include arrows) but I would like my legend to show one colored line with one label (e.g. green for waste water).
The option exists in ArcGis Desktop for the legend option to only show classes from heading, please add this to Pro.
Hello @JackLau I merged the Idea you just posted with this existing Idea, since they covered the same topic. Please add your vote using the Kudos button above!
Thank you!
This is slowing down converting to Pro. I used this option in ArcMap when I had layers with very similar unique symbols and when I use Symbol Levels, which requires using unique symbols to work. I have dozens of maps and layers with a heading "Show" to pick what is shown in the legend.
@AubriOtis - any idea when this option will be available again?
In Product Plan means it is actively being worked on. It's hard to say for sure, but look for it in the next release or two.
This Idea has been implemented in ArcGIS Pro 3.2. Please see the What's New documentation for more new features in Pro 3.2.
Hi @AubriOtis,
I can't find this feature neither on the documentation page you posted a link to above nor in my legend properties. Could you provide some more information where to find this setting?
Ilka
It's slightly hidden in the 'legend item groups' at the foot of the legend panel.
Interesting, I do not have that option... I am on version ArcGIS Pro 3.2.2, this should be included, right?
Ok, if you only have one heading it doesn't show anything there... makes sense.
I can now add a legend and only include symbols under a specific heading, yay! This lets me remove duplicates that are already symbolized in legends from other map frames.
I can't seem to add multiple instances of the same layer to the legend as you could in ArcMap, though. I want my legend to be able to insert a symbol from Layer 2 in between two headings from Layer 1. Is there a way to do this in Pro?
I agree, that limits the benefits of that functionality quite a bit! If you want classes from different headings but with other layers in between, you have to go back to duplicating layers...
Sign in to post, follow content, and more. New here? Register for free.
