I may be missing this, but, is there a way to incorporate preset halo/shadow onto the existing MapViewer symbols in the way that the MapViewClassic did?
Hello @EricG
When you say "preset" do you mean like with the feature service?
Good Morning @EricG
I do not see the image.
The post didn't come through above but going off of info in the post we do not have that picture marker symbol shapes in the new Map Viewer.
We do have a marker based symbol for shapes where you can define the color for the symbols, outline colors, change the size without making the symbol blurry. You can also use effects to add a similar drop shadow but also control the direction, size and color of the shadow.
MVC
NMV
@RussRoberts
He is talking about the point symbology that is preset in the classic map viewer. See my attachment.
you can download the icons and publish as your own webstyle and use that in new map viewer
example icon:
https://static.arcgis.com/images/Symbols/Shapes/GreenCircleLargeB.png
Where do you get the icons?
Just saved the web map with the symbols you want and you will see a url in the web map JSON for the esri symbol and it will be a png you can download.
You can use ago-assistant to find the url or chrome web dev tools.
@EricG and @RussRoberts
Something else I just tried was opening a classic map viewer web map, saving it as another map as a test then opening it in the new map viewer. The symbology was preserved for the new web map viewer map.
Yup that will work.
If you do use web styles though - they are not supported in classic viewer and other older 3.x JSAPI applications like WebStyles.
