I have multiple officers using the same survey123 form on their work iPhone. one officer in particular has login issue from the very beginning. In this case, whenever he needs to access the survey, he needs to go through the login screen each time.
The survey is from AGO and he is a member of the group that can access the survey. He is using the latest OS built and Survey123 APP. Login is through azure ad
any thought what may be causing the app not retaining user login info?
