function activateNavigation(navType) { if (navType) { navToolbar.activate(navType); // for some reason, when switch ZoomIn to ZoomOut or vice versa, the pan operation is enabled. // I believe it is a bug. Here is a workaround. if (navType !== "pan" && map.isPan) { map.disablePan(); } // set map cursor based on the navigation type switch (navType) { case esri.toolbars.Navigation.PAN: map.setMapCursor("move"); break; case esri.toolbars.Navigation.ZOOM_IN: case esri.toolbars.Navigation.ZOOM_OUT: map.setMapCursor("crosshair"); break; default: map.setMapCursor("default"); break; } } }
dojo.require("esri.toolbars.navigation"); var navToolbar;
navToolbar = new esri.toolbars.Navigation(map);
