I have not been able to make a proper code as I am new to Arcade. What I want to do is, split a line feature A by a start point of another line feature B. When I draw a line B from somewhere on the line A, the line A is split at the start point of line B. Also, the feature A has field "ID_A". For example, value of 10, the attribute of the "ID_A" is going to be updated to 11 and 12 respectively when the feature A is split into two features.
Based on a code that I found on web, I managed to prepare a code to split a line by a point feature. This works well that also achieve the update of attribute with using NextSequenceValue. But I am struggling to achieve this using a line feature instead of a point.
Much appreciated if anyone give me hint.
