Has anyone had the experience where ArcGIS Pro suddenly loses the ability to receive input from the mouse? Occasionally, my ArcGIS Pro project will get into a mode where I need to shut it down using the task manager because any click event on the screen results in the last tool I used being activated despite where I am clicking.
For example, I click the 'Select' tool on the Map ribbon, and select a polygon in the map. Then all subsequent clicks result in selecting that same polygon. When I click the 'x' to close the application, the polygon flashes as if it has been selected again. At this point, I need to close the application using the task manager.
I have the latest release, and this behaviour occurs across multiple .aprx files, so I don't think it is a corrupt file.
Jen
