var sfs = new SimpleFillSymbol(SimpleFillSymbol.STYLE_FORWARD_DIAGONAL, new SimpleLineSymbol(SimpleLineSymbol.STYLE_SOLID, new Color([255, 0, 0]), 2), new Color([255, 255, 0, 0.5]));
do i have to query only the feature layer is there an option for ArcGisDynamicMapService layer.Secondly for highlighting is there any alternative way is it only this way?
<!DOCTYPE html> <html> <head> <meta http-equiv="Content-Type" content="text/html; charset=utf-8"> <meta http-equiv="X-UA-Compatible" content="IE=7, IE=9, IE=10"> <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"> <title>Feature Layer Only Map</title> <link rel="stylesheet" href="http://js.arcgis.com/3.6/js/esri/css/esri.css"> <style> html, body, #map { height: 100%; width: 100%; margin: 0; padding: 0; } </style> <script src="http://js.arcgis.com/3.6/"></script> <script> require([ "dojo/dom-construct", "esri/map", "esri/layers/FeatureLayer", "esri/geometry/Extent", "esri/InfoTemplate", "dojo/domReady!" ], function( domConstruct, Map, FeatureLayer, Extent, InfoTemplate ) { var bounds = new Extent({ "xmin":-16045622, "ymin":-811556, "xmax":7297718, "ymax":11142818, "spatialReference":{"wkid":102100} }); var map = new Map("map", { extent: bounds }); var url = "http://sampleserver6.arcgisonline.com/arcgis/rest/services/WorldTimeZones/MapServer/2"; var template = new InfoTemplate("World Regions", "Region: ${REGION}"); var fl = new FeatureLayer(url, { id: "world-regions", //infoTemplate: template }); require(["dojo/on", "esri/symbols/SimpleFillSymbol", "esri/symbols/SimpleLineSymbol", "dojo/_base/Color", "esri/graphic"], function(on, SimpleFillSymbol, SimpleLineSymbol, Color, Graphic) { on(fl, "click", function(evt) { var queryTask = new esri.tasks.QueryTask(url); //build query filter var query = new esri.tasks.Query(); query.returnGeometry = true; query.where = "REGION='Central America'"; dojo.connect(queryTask, "onComplete", function(featureSet) { map.graphics.clear(); var sfs = new SimpleFillSymbol(SimpleFillSymbol.STYLE_FORWARD_DIAGONAL, new SimpleLineSymbol(SimpleLineSymbol.STYLE_SOLID, new Color([255, 0, 0]), 2), new Color([255, 255, 0, 0.5])); //QueryTask returns a featureSet. Loop through features in the featureSet and add them to the map. dojo.forEach(featureSet.features,function(feature){ var graphic = feature; graphic.setSymbol(sfs); map.graphics.add(graphic); }); }); queryTask.execute(query); }); }); map.addLayer(fl); } ); </script> </head> <body> <div id="map"></div> </body> </html>
Great , I know i have to use query task to query the service.But my question is if i query http://sampleserver6.arcgisonline.com/arcgis/rest/services/WorldTimeZones/MapServer/2which has reqion as fields that it return , i will get string but how will i use this string to highlight map , how will i identify the reqion or how i get that reqion object.Plz help.Also can i query only feature layer , i check in ArcGISDynamicMapServiceLayer there is no help for query.
Thanks a lot, by the highlighting part is where i am struck actually , the example that u pointed out get the region attribute when u click on map but here what i want is vice versa, i want to provide region and highlight , this is very important for me so please point out something.
1)DO i have to choose only from existing rest service from arcgis , cant i create myself services.
2) I need a world map where i can identify each country by an two letter word id , so that if i want to highlight us , then i can something like dojo.byId('us") and apply some graphic code to highlight it.
require(["dojo/on", "esri/symbols/SimpleFillSymbol", "esri/symbols/SimpleLineSymbol", "dojo/_base/Color", "esri/graphic"], function(on, SimpleFillSymbol, SimpleLineSymbol, Color, Graphic) { on(fl, "click", function(evt) { // clears current selection map.graphics.clear(); // create new graphic with selected graphic's geometry var graphic = new Graphic(evt.graphic.geometry); // create a new symbol for the graphic var sfs = new SimpleFillSymbol(SimpleFillSymbol.STYLE_FORWARD_DIAGONAL, new SimpleLineSymbol(SimpleLineSymbol.STYLE_SOLID, new Color([255, 0, 0]), 2), new Color([255, 255, 0, 0.5])); // add symbol to the graphic graphic.setSymbol(sfs); // add the graphic to the map map.graphics.add(graphic); }); });
require(["dojo/on"], function(on){ on(fl, "click", function(evt) { // do something with evt.graphic - get it's attributes and display them somewhere, edit it's symbol, reshape it etc. }); });
