Is there a a way to make it so the leaders on a label created with either engine start from underneath the geometry?
This keeps happening and it looks bad, so I'd like to avoid it .
Thanks!
Pretty much my number one gripe about labels. They probably don't do it because the leader would be visible under the label and would require the label to be masked.
But you would think with Pro that you could set up attribute fields to say yes it has a leader or no and then yes it has a halo or no etc.
Not a big fan of annotation myself, really only good in a narrow range of scale.
It has been made as a suggestion a number of times.
I did create label points once and then drew in a label leader. The beginning of the leader was white. I would do that for the difficult locations.
I found a working solution, but it's not as good as automatic.
Leader Line Feature Offset - Esri Community
If you all haven't voted for that idea yet, please do.
