@HusseinNasser2
I have a SDE database and I have a related table within the database. The table is housing records submitted from Survey123 for liquid level readings. I would like to visual some of these submitted readings, but I don't want to create a join to do so. As an alternative I have implemented an Attribute Rule for the field containing the values I would like to visual by. In another layer within my database I have added a new field in order to write the value from the table into. I have done this successfully. So when a new record is inserted in the related table, my Attribute Rule successfully executes and writes my desired value into the other layer within my database. The only issue is that the value doesn't end up in the related table. It's like the Attribute Rule is stealing it before it is finally inserted into the table.
Is this expected behavior? A way to work around this?
Any insight you could provide would be much appreciated!
Please see my code below:
//Field: toc_to_liquid_1
//Trigger: insert
//Execution: Exclude from application evaluation
//The example below is a calculation rule on a text field of a liquid level survey table.
//When a new record is inserted within the survey table the value from the text field is written into a corresponding field in the master layer
// Master layer accessed as a Feature Set
var masterLayer = FeatureSetByName($datastore,'L0RMCDemo_GIS_SDE_RMC_Demo_Master_Layer', ['globalid', 'Point_ID', 'current_liquid_level'], false);
//Extraction well point_id
var pointID = $feature['well_id'];
// Filter statement (SQL) - access variable with @
var filterStatement = 'Point_ID = @pointID';
// Filter the master layer by the filter statement - grabs the value that matches from Master to LL Table
var masterFilter = Filter(masterLayer, filterStatement);
var currentTOC = [];
for (var record in masterFilter) {
currentTOC = [{
'globalid': record.GlobalID,
'attributes': {
'current_liquid_level': $feature.toc_to_liquid_ft_1
return {
'edit': [{
'className': 'RMCDemo_GIS.SDE.RMC_Demo_Master_Layer',
'updates': currentTOC
