Hi all,
I'm trying to update a feature layer with an excel sheet. However I can't get the date to be working properly:
- When date is just the plain date (without time) in the Excel sheet -> Output (Dashboard): entered date with a time stamp - which is wrong. I'd like it to show "14.09.2021 16:00" for example.
- Date format in Excel is "Date" + a text "16:00" (custom format) -> AGOL does not recognize the additional text. Quite obvious, actually. Excel format does not add to the value itself.
- Date in the sheet is combined as: =TEXT(today()-1; "DD.MM.JJJJ")&TEXT(L2;" HH:MM:SS")
This should give me yesterdays date (as text) + the time from field L2 (as text) -> "13.09.2021 14:00:00"
This gives me exactly what I need inside the spreadsheet hoewever AGOL does not recognize the additional time stamp.
- When the date is set to just a value of "14.09.2021 16:00" AGOL does recognize the date _and_ the time, but the spreadsheet is no longer comfortable to use because of all the manual date changes.
Is there a way to format Excel dates to be recognized by AGOL?
Or alternatively: Is there a way to shut off the time-extention when using the date on a dashboard? Right now, when I'm using the field "Date", the result is: "14.09.2021 02:00:00" (2 AM due to UTC time shift)
Best regards
Tobias
