Hi, I'm new to CityEngine. I'm interesting in viewshed and view dome creation. I want to create a view dome, and look through the window with barriers to analysis the visibility outside the room, but it doesn't work well. The viewshed or view dome will not analysis the models nearby (as if in a cubic), when the view distance is 3000, the length of the cubic side is about 30.
Can you help me, please!
Thank you very much!
Hi @Anonymous User,
Your observation is correct, this is a limitation we currently have: There is a minimal distance corresponding to the View Distance value you can set in the Inspector or using the Handles. The value of the minimal distance is approximate 1% of the View Distance. So, when your View Distance is 3000 the minimal distance will be 30 and when your View Distance is 30 your minimal distance will be 0.3.
I see one possible workaround, that could do the trick for you:
Best,
Jonas
