I am a new user to ArcOnline and ArcCollector. Through my work, I have an ArcGIS Professional Advanced account and am listed as a User at this time. After working through tutorials such as this one: https://www.esri.com/arcgis-blog/products/collector/field-mobility/make-your-first-collector-map/ I have come to notice that my Content screen looks different than all the examples I have seen. Instead of having the buttons "Add Item" and "Create" (which would give me access to Feature Layer Templates to create my map for ArcCollector), I have the buttons "New Item" and "Create App", which only allows me to upload items via URL. Does anyone have any insight on this? I am currently stuck on how to move forward with creating a map to then use in ArcCollector. Thank you!
I think you may need at least a Publisher role or higher if using the default roles. Note their ability to create "hosted" feature layers and not just "Create content" ie maps and groups like a User can. In the workflow you are following, a hosted feature layer is being published.
Hi @jmohlman ,The UI for ArcGIS Online has changed since that blog was posted. If you click on "New Item" and then "Feature Layer" you will see the screen to create from a Template (like you see in the blog). That should help move you forward.
Regards,
Colin
Colin,
Thank you for your response! Sadly, I do not have the option of "Feature Layer" when I select "New Item". I have included images below of my "New Item" and "Create App" selections to help provide more information
Totally skipped over that part of your post. This is likely a limitation of your user type or role. Can you have your administer take a look at your ArcGIS Online account within the scope of this documentation? You likely an adjustment to your user role.
Not a problem. I thought that user restrictions may be an issue before, but when I read over the documentation previously it seems like I should have access? I am on a GIS Profession Advanced License with the role of User.
From the documentation...
When selecting "role" options with GIS Professional Advanced there was no "Creator" option and it appears there could only be one Administrator. Though it would seem odd that only administrators could create Maps or Feature Layers?
Thank you for all your help. My google searches thus far have been a dead end.
