I want to create a project template based on a map that contains data from an enterprise database. I get an error message for layers retrieved via a database connection file that does not store user and password. The error is: ERROR 001707: Data cannot be opened: SDE (SERVER = xyz; INSTANCE = sde: oracle $ xyz $ xyz; DBCLIENT = oracle; ....
The reason why the user and password are not stored in the database connection file is that the users must connect with their own DB-user to create a new project from the template.
No error when users/password is stored in the database connection file.
Is it a bug? If not, how can users connect/switch to their own DB-user?
I do not want to create a template for each user.
I am using Pro 2.7.
