After running 'Export training data for deep learning' tool in Arcgis Pro, named as 'training_folder', I did data augmentation on the 'training_folder' using arcgis.learn.prepare_data. Then,I would like to save the result of data augmentation into a folder. However, it has error Below are my code in Python Arcgis Pro:
import arcpy, arcgis
from arcpy.ia import *
arcpy.CheckOutExtension("ImageAnalyst")
data=arcgis.learn.prepare_data(r'C:\training_folder')
data.save(r'C:\Data\Deep_Learning\test')When I run this script, it has error as below:
File "<string>", line 1, in <module>
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\fastai\basic_data.py", line 155, in save
try_save(self.label_list, self.path, file)
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\fastai\torch_core.py", line 411, in try_save
target = open(path/file, 'wb') if is_pathlike(file) else file
PermissionError: [Errno 13] Permission denied: 'C:\\Data\\Deep_Learning\\test'Could you please help me how to save the result of data augmentation into a folder?
Thank you for your help.
