I have survey123 connect and published it to web app. Do we have webhook for enterprise portal? I only found ArcGIS Online documentation. Please advise. Thank you.
Alex
Hi Alex,
See if below Technical article can help you..
https://support.esri.com/en/technical-article/000025025
Krish
You can use Integromat to publish webhooks connected to ArcGIS Enterprise. At this point I do not believe Microsoft Power Automate works only with ArcGIS Online, not Enterprise.
@Andrew-Bowne
Thank you for the information. Is it free to use intergromat? Do we have documentation for this?
I am bumping up this post since the solution provided below seems out to date.
We have survey running in our ArcGIS Enterprise.I would like to have my webhook on Microsoft power automate but it only connect to agol.
Did anybody managed to get it work with Enterprise?
Enterprise Support for Power Automate has been recently released:
https://www.esri.com/arcgis-blog/products/microsoft-365/announcements/arcgis-enterprise-connector-for-power-automate/
is there a solution for this? i have the same need here.
