I'm working in ArcMap 10.3 with a University license, and after a handful of actions (i.e, zoom-in/out, select object, clip, edit, etc.) the map image will stop refreshing. This prevents me from seeing changes I've made to the map unless I use the pan tool and move the map. A simple example is once this starts happening if I select by attribute my selections will not be highlighted until I move the map with the pan tool.
Has anyone had this issue before or have any suggestions for how to remedy the issue?
