Samantha,for the Go To X-Y tool with the coordinates as shown you need to change the entry format to "decimal degrees"
Thanks a ton everything worked great! I just have a question at step 5, when I am going to edit and selecting North American Datum 1983. Is that defining the coordinate system of my xy input or is it projecting it?
Samantha,5. at the bottom of the box hit EDIT... and Select in Geographic Coordinate Systems folder North Americafolder: "North American Datum 1983.prj "which will show up as GCS_North_American_1983Hardolph
The problem is that you selected Projected Coordinate System as a 'Coordinate System of Input Coordinates' and it should be Geographic Coordinate System (GCS).Google uses WGS 1984 as a GCS so to use this GCS for your data you have to:- in Spatial Reference Properties dialog box click Select- then Geographic Coordinate System -> World -> WGS 1984.prjBTW: coordinates assignment standard is:X Field - Longitude: -97.105016Y Field - Latitude: 33.159106
By chance are your longitudes missing a negative sign?
You mixed up your lat and longs.
I am simply trying to make point shapefiles from x,y data. It doesn't seem to work, perhaps I am doing it incorrectly. Please check the image below it fully illustrates the issue I am having.[ATTACH=CONFIG]13683[/ATTACH]Thank you
