I issued a problem while sharing web tool to a corporate ArcGis server.
I created a python script that works perfectly locally and passes preposting analysis but when I share it and try to run as a service, I get an error:
“line 98 SyntaxError: (unicode error) 'utf-8' codec can't decode byte 0xf1 in position 8: invalid continuation byte”
When I downloaded file from server’s directory I saw no syntaxis problems but I found out that in my code some strings replaced by “g_ESRI_variable_”s. That are:
1.Pathes to projected data – it was replaced correctly.
2.Field mapping string – long string and it have been replaced incorrectly. Part of a spring just disappeared.
#Field maping string to map fields while copy landplots
copy_class_map_field = 'GlobalID "GlobalID" false false true 38 GlobalID 0 0,First,#,DBO.Terra_landplots_Layer,GlobalID,-1,-1;id_accounted "id_accounted" true true false 4 Long 0 10,First,#,DBO.Terra_landplots_Layer,id_accounted,-1,-1;Kluster_name "Kluster_name" true true false 70 Text 0 0,First,#,DBO.Terra_landplots_Layer,Kluster_name,0,70;District "District" true true false 70 Text 0 0,First,#,DBO.Terra_landplots_Layer,District,0,70;Region "Region" true true false 70 Text 0 0,First,#,DBO.Terra_landplots_Layer,Region,0,70;Vilage_consil "Vilage_consil" true true false 100 Text 0 0,First,#,DBO.Terra_landplots_Layer,Vilage_consil,0,100;Vilage "Vilage" true true false 70 Text 0 0,First,#,DBO.Terra_landplots_Layer,Vilage,0,70;Square "Square" true true false 8 Double 8 38,First,#,DBO.Terra_landplots_Layer,Square,-1,-1;Square_second_cat "Square_second_cat" true true false 8 Double 8 38,First,#,DBO.Terra_landplots_Layer,Square_second_cat,-1,-1;In_of_field_persent "In_of_field_persent" true true false 8 Double 8 38,First,#,DBO.Terra_landplots_Layer,In_of_field_persent,-1,-1'
#Field maping string to map fields while perform spatial join cliped landplots and fields
spatial_join_map_field = 'GlobalID "GlobalID" true false false 38 GlobalID 0 0,First,#,memory\\worked,GlobalID,-1,-1;id_accounted " id_accounted " true true false 4 Long 0 10,First,#,memory\\worked,id_accounted,-1,-1;Kluster_name "Kluster_name " true true false 2147483647 Text 0 0,First,#,memory\\worked,Kluster_name,0,2147483647;District "District" true true false 2147483647 Text 0 0,First,#,memory\\worked,District,0,2147483647;Region "Region" true true false 2147483647 Text 0 0,First,#,memory\\worked,Region,0,2147483647;Vilage_consil "Vilage_consil" true true false 2147483647 Text 0 0,First,#,memory\\worked,Vilage_consil,0,2147483647;Vilage "Vilage" true true false 2147483647 Text 0 0,First,#,memory\\worked,Vilage,0,2147483647;Square "Square" true true false 8 Double 8 38,First,#,memory\\worked,Square,-1,-1;Square_second_cat "Square_second_cat" true true false 8 Double 8 38,First,#,memory\\worked,Square_second_cat,-1,-1;In_of_field_persent "In_of_field_persent" true true false 8 Double 8 38,First,#,memory\\worked,In_of_field_persent,-1,-1;ZD_1_GlobalID "ZD_1_GlobalID" true true false 38 Guid 0 0,First,#,memory\\worked,ZD_1_GlobalID,-1,-1;Name "Name" true true false 255 Text 0 0,First,#,C:\\Users\\d.lukash\\Documents\\ArcGIS\\Projects\\Landplot_manadgment\\T3ADF.sde\\T1.DBO.Fields_14,Name,0,255'
replaced by
# Esri start of added variables
g_ESRI_variable_1 = 'Terra_landplots_Layer,Square_second_cat,-1,-1;In_of_field_persent "In_of_field_persent" true true false 8 Double 8 38,First,#,DBO.Terra_landplots_Layer,In_of_field_persent,-1,-1'
g_ESRI_variable_2 = 'DBO.Fields_14,Name,0,255'
copy_class_map_field = g_ESRI_variable_1
spatial_join_map_field = g_ESRI_variable_2
I do not know if Syntax Error have something common with this replacement. Is there some documentation about it? What I should do to get my code runs correctly on server after sharing.
Thanks for help!
