Dear all,
I have question regarding using arcpy to access to enterprice geodatabase. According to my research, the enterprice gdb is defined with a sde file on harddrive and I can just use the filepath of this sde as the workspace to access to this gdb. I have been doing this for a number of sql gdb and it works fine for me. The steps are as followings:
- Create/define a Database Connection in ArcCatelog, this will create a sde file
- Using the filepath of sde file for the workspace for arcpy code. For example:
ws = "C:\\Users\\user\\AppData\\Roaming\\ESRI\\Desktop10.8\\ArcCatalog\\myGDB.sde"
layerPath = ws + "\\featureclassrName
desc = arcpy.dDescribe(layerPath)
gdb_df = pd.DataFrame.spatial.from_featureclass(layerPath)
However, I encountered an Enterprice gdb server that is not defined with sde, rather, it is defined with gds. For example, "C:\\Users\\user\\AppData\\Roaming\\ESRI\\Desktop10.8\\ArcCatalog\\myGDB.gds". If I use this file path for ArcPy, it will return "Cannot open file" msg.
So, my question is, how to access Enterprice Geodatabase Server define with *.gds file? Do I have to created Database Connection in ArcCatelog instead of Database Server?
Thanks a lot and have a nice weekend!
Ming
