I am attempting to insert a custom button in the right click context menu highlighted in red in the attached image. I am unable however, to determine the refid of this specific context menu. I have scoured https://github.com/esri/arcgis-pro-sdk/wiki/DAML-ID-Reference-Editing.daml#menus to no avail. Because I turned on the capability, when I hover over any button, I am able to see its id but in this case, none of the commands in this context menu shows any id on hovering. Any idea how I can retrieve the id of this context menu for update purposes? @CharlesMcLeod @Wolf @UmaHarano
it appears that that menu is off the user control itself and not from daml so it cannot be customized
@MarvisKisakye1 Did you get any solution of this? I am also looking for same solution
I have tried many ways in config.daml but no success, below are sample entries in file i tried.
<!-- 1. esri_editing_Attributes_RelatedNonFeatureRowContextMenu: Drill down from the spatial feature to the Non Spatial object for the Context Menu Item to appear e.g. Right-clicking a Related record (child record) in the top selection tree. --> <updateMenu refID="esri_editing_Attributes_RelatedNonFeatureRowContextMenu"> <insertButton refID="POC_Addins_CustomContext_Views_CatalogHelpBtn" separator="true" placeWith="esri_editing_Attributes_StandaloneTablePropertiesContextMenuItem" /> </updateMenu> <!-- 2. esri_editing_Attributes_NonFeatureRowContextMenu: is used for standalone table records that are open in the Attributes Pane but are not currently being viewed as a "related child" of a map feature. e.g. In ArcGIS Pro, when you open a standalone table (one without geometry) and select a row, that row appears in the Attributes Pane. This specific refID controls the right-click menu for that record's entry in the selection tree.--> <updateMenu refID="esri_editing_Attributes_NonFeatureRowContextMenu"> <insertButton refID="POC_Addins_CustomContext_Views_CatalogHelpBtn" separator="true" placeWith="esri_editing_Attributes_StandaloneTablePropertiesContextMenuItem" /> </updateMenu> <updateMenu refID="esri_editing_Attributes_FeatureContextMenu"> <insertButton refID="POC_Addins_CustomContext_Views_CatalogHelpBtn" separator="true" placeWith="esri_editing_Attributes_LayerPropertiesContextMenuItem" /> </updateMenu> <!-- esri_editing_Attributes_FeatureRowContextMenu: Right-clicking a Map Feature (Point, Line, Poly) in the top selection tree. --> <updateMenu refID="esri_editing_Attributes_FeatureRowContextMenu"> <insertButton refID="POC_Addins_CustomContext_Views_CatalogHelpBtn" separator="true" /> </updateMenu> <!-- esri_editing_AttributesPaneAttributesContextMenu: Right-clicking the actual field values/cells in the bottom grid. --> <updateMenu refID="esri_editing_AttributesPaneAttributesContextMenu"> <insertButton refID="POC_Addins_CustomContext_Views_CatalogHelpBtn" separator="true" /> </updateMenu> <updateMenu refID="esri_editing_AttributesPane_GridContextMenu"> <insertButton refID="POC_Addins_CustomContext_Views_CatalogHelpBtn" separator="true" /> </updateMenu>
Please refer screenshot:
