The Spatially Enabled Dataframe has a .to_featurelayer() method which allows users to easily publish a feature service from a Spatially Enabled Dataframe. It's a great, long desired capability with really only one shortcoming that I can find.
The SEDF's .to_featurelayer() method has the unfortunate behavior of sanitizing column names, even if the column names are valid to begin with.
The result is that its changes column names from their original case to snake_case. For example 'storeName' gets changed to 'store_name' when you utilize the .to_featurelayer() method to publish the data frame as a feature layer, even though there is absolutely nothing invalid at all about a feature layer with a field named 'storeName'.
Interestingly however, the .to_featureclass() method exposes a sanitize_columns parameter which is defaulted to True. Meaning you can set that parameter to False on the .to_featureclass() method to avoid this behavior, but for whatever reason this parameter wasn't exposed on the .to_featurelayer() method.
Please expose a 'sanitize_columns' parameter on the SEDF's .to_featurelayer() method so that we can disable this feature if we so desire. Like the SEDF's .to_featureclass method, the 'sanitize_columns' parameter can be defaulted to True to avoid an unexpected change in behavior for users who might already be using this.
