Hi All,
I have recently been moving a project of mine from local builds (windows) to Jenkins (ubuntu).
Everything builds fine on my local machine but when I try to build on Jenkins the build fails with the following diff in build-report.txt.
/dist/dojo/dojo.js:. OPTIMIZER FAILED: JavaException: java.lang.RuntimeException: Exception parsing "dojo.js.uncompressed.js"
I beleive this is the closure compiler having an exception:
Has anyone else had this issue?
Is there a way to get more verbose logging from the closure compiler?
Is the something else I may be able to do to find the cause of this issue?
Cheers,
Jethro
P.S. FYI
Jenkins:
ubuntu@ip-xyz-xyz-x-xyz:~$ java -version
openjdk version "1.8.0_292"
OpenJDK Runtime Environment (build 1.8.0_292-8u292-b10-0ubuntu1~18.04-b10)
OpenJDK 64-Bit Server VM (build 25.292-b10, mixed mode)
ubuntu@ip-xyz-xyz-x-xyz:~$ npm -v
7.15.1
ubuntu@ip-xyz-xyz-x-xyz:~$ node -v
v16.2.0
Local:
C:\DEV2021\OctonionDojo>java -version
java version "1.8.0_241"
Java(TM) SE Runtime Environment (build 1.8.0_241-b07)
Java HotSpot(TM) 64-Bit Server VM (build 25.241-b07, mixed mode)
C:\DEV2021\OctonionDojo>npm -v
7.15.1
C:\DEV2021\OctonionDojo>node -v
v12.16.2
