I set up a webapp about a year ago for editing related tables using Smart Editor. Recently I have tried to create another webapp to update other features using Smart Editor. In this new app and in the past app (that was working) I see no ability to add features or edit the features. I get the following message when opening the Smart Editor "Select a template to create features." I have tried a few different themes within the webapp builder as I had read there were issues with the Tab theme. I have always been using the Billboard theme with no issues until now (or the past few weeks). Thanks for any help.
Hi @MRJohnson ,
I looked through this issue with our developer and it looks like a recent update may have introduced an issue with older applications. We will work on fixing this moving forward. In the meantime, it appears you can fix your application with the following workaround:
1. Open your application in builder mode (Edit Application)
2. Open the Smart Editor widget configuration.
3. Go to the General Settings tab.
4. Click the Geocoder Settings button and click Validate, click OK.
5. Click OK to close the Smart Editor configuration.
6. Save your application.
You should then be able to create/update features.
Let me know if you encounter any other issues.
The original bug that was causing this issue has now also been fixed from our end.
That would be great! Please add the following username AlixSolutions to the group.
Thanks!
I can try to quickly debug this with you in the meantime. Please provide the following if possible:
I have submitted a request to be able to do this through my organization. I am not sure how long that will take but hopefully can have a solution to post back here once I hear back from them. If anyone else has had similar issues would love to hear what you were able to do to get the widget to work.
Hi @MRJohnson,
Thank you for reaching out with this issue. Different things could be going on here, and someone may need to look more closely at your application to understand the source of the issues you are experiencing.
Please, if you have the time, would you be able to contact Esri Support to review this issue? Thank you!!
