Hi there,
I'm looking for help on fixing an error while trying to add a new feature class into an existing feature dataset called Province.
Error in Arc Catalog while pasting the new feature class called "Rivers" or importing:
Open Failed: Error opening feature class Layer not found [GIS. Communities]
The feature class "Communities" no longer exists. It is not needed. This is a versioning environment using Oracle 12c.
I have tried different things such as re-creating the fc "Communities", I can see it on both sides inside Arc Map and also Oracle SQL. But, when I try to insert the new fc into fd, it doesn't let me.
I did admin database management: reconcile, post, delete all versions, compress, rebuild indexes, analyze, etc.
I also did the diagnose and repair version tables and metadata and they run successful without errors.
When, I run again rebuild indexes, I checked the python script log and that province/state was skipped. Then, I try to do it manually through arcmap. But, it doesn't let me to access it through properties. It looks like the issue is with the index and some broken links. I do need that feature class but I would like to keep the other feature classes.
You may have encounter this error before. I would like to repair it to keep the names of the other fcs. Your help is appreciated.
Nat
