I configured the Analysis widget with Extract Data functionality for a client that wants to export data to KML. The issue is that output KML doesn't show the proper layer name or attributes when it's added to Google Earth. The target layer is a layer view created from a AGO-hosted feature layer. Under the layer view's visualization tab, I set the popup title to be "ID" field and the service's REST end point shows that the "Display Field" is also set to the same ID field. In the Google Earth, the it shows "no name" as label rather than the ID. How can I show the exported output to be labeled per the ID field?
