https://developers.arcgis.com/android/kotlin/sample-code/generate-geodatabase/
I am working on this Link Above, though I am able to load the map as per TPK File stored but not able to see layers which are created over the map.
We have a SketchEditor UI component that helps in edit or sketch of a new point, line, or polygon geometry etc on to a map. Here is the sample for using SketchEditor,https://github.com/Esri/arcgis-runtime-samples-android/tree/main/java/sketch-editorHere is the list of the supported SketchCreationModes,https://developers.arcgis.com/android/api-reference/reference/com/esri/arcgisruntime/mapping/view/SketchCreationMode.htmlFrom the sketchEditor you can get the geometry which should contain details of all the parts & vertices of the geometry.ThanksRama
Also , It would be great as have some queries related to annotations pasting below.
On One mapView, Can we draw line, Circle and Polygon and capture their lastcoordinates which completes Points with above. As we are enabling multiple functionalitiesonTouch() listener and on singleTapConfirmed() will it be feasible to draw and get points?Thanks In Advance if you can help us with tutorials of drawing circle, line and polygon?
It works fine now, but most of times it fails to load data. It showed up data on map generated offline.
Thanks for reply.
HI,In this sample, when you click on the Generate Button. The data from the feature service will be downloaded offline and once the download is complete, the features should render from local geodatabase. Do you see the progress reported in the dialog or any error from LogCat in the Job Status while downloading ?ThanksRama
