I don't understand how to add a simple symbology to a feature class created in the the script and add it to a new map. Well I kind od did figure it out but this my code seems ridiculously long just to add symbology from a existing layer.
I thought up to line 21 would be good enough to set the symbology I need. However, i had to add line 22,23,24 to get what I want.
Basically I want the user to enter in a feature class, set a SQL expression and isolate the feature they want. Take that feature save it, add it to a different mxd, apply the symbology from an existing layer and save the mxd.
I've heard of Derived and SetOutputParameters and apply the symbology there but I dont understand how to write that in the code.
<SPAN class="keyword token">import</SPAN> arcpy<SPAN class="punctuation token">,</SPAN> datetime<SPAN class="punctuation token">,</SPAN> os<SPAN class="punctuation token">,</SPAN> sys<SPAN class="punctuation token">,</SPAN> string
date <SPAN class="operator token">=</SPAN> datetime<SPAN class="punctuation token">.</SPAN>datetime<SPAN class="punctuation token">.</SPAN>now<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN>
namefile <SPAN class="operator token">=</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>GetParameterAsText<SPAN class="punctuation token">(</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">)</SPAN>
prjbdy <SPAN class="operator token">=</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>GetParameterAsText<SPAN class="punctuation token">(</SPAN><SPAN class="number token">1</SPAN><SPAN class="punctuation token">)</SPAN>
express <SPAN class="operator token">=</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>GetParameterAsText<SPAN class="punctuation token">(</SPAN><SPAN class="number token">2</SPAN><SPAN class="punctuation token">)</SPAN>
mxdpath <SPAN class="operator token">=</SPAN> <SPAN class="string token">"C:\Users\Adam\Desktop\Test5.mxd"</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>CreateFileGDB_management<SPAN class="punctuation token">(</SPAN>namefile<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"\\SlopeAdam"</SPAN> <SPAN class="operator token">+</SPAN> date<SPAN class="punctuation token">.</SPAN>strftime<SPAN class="punctuation token">(</SPAN><SPAN class="string token">"%Y%m%d"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="operator token">+</SPAN> <SPAN class="string token">".gdb"</SPAN><SPAN class="punctuation token">)</SPAN>
fgdb <SPAN class="operator token">=</SPAN> namefile <SPAN class="operator token">+</SPAN> <SPAN class="string token">"\\Slope"</SPAN> <SPAN class="operator token">+</SPAN> date<SPAN class="punctuation token">.</SPAN>strftime<SPAN class="punctuation token">(</SPAN><SPAN class="string token">"%Y%m%d"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="operator token">+</SPAN> <SPAN class="string token">".gdb"</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>env<SPAN class="punctuation token">.</SPAN>workspace <SPAN class="operator token">=</SPAN> fgdb
mxd <SPAN class="operator token">=</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>mapping<SPAN class="punctuation token">.</SPAN>MapDocument<SPAN class="punctuation token">(</SPAN>mxdpath<SPAN class="punctuation token">)</SPAN>
df <SPAN class="operator token">=</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>mapping<SPAN class="punctuation token">.</SPAN>ListDataFrames<SPAN class="punctuation token">(</SPAN>mxd<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>MakeFeatureLayer_management<SPAN class="punctuation token">(</SPAN>prjbdy<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"prjbdy_Layer"</SPAN><SPAN class="punctuation token">,</SPAN>express<SPAN class="punctuation token">)</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>CopyFeatures_management<SPAN class="punctuation token">(</SPAN><SPAN class="string token">"prjbdy_Layer"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"test3"</SPAN><SPAN class="punctuation token">)</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>MakeFeatureLayer_management<SPAN class="punctuation token">(</SPAN><SPAN class="string token">"test3"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"test4"</SPAN><SPAN class="punctuation token">)</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>ApplySymbologyFromLayer_management<SPAN class="punctuation token">(</SPAN><SPAN class="string token">'test4'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"C:\Users\Adam\Desktop\SlopeAnalysis\prjbdy_Layer.lyr"</SPAN><SPAN class="punctuation token">)</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>SaveToLayerFile_management<SPAN class="punctuation token">(</SPAN><SPAN class="string token">'test4'</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="string token">"C:\Users\Adam\Desktop\SlopeAnalysis\prjbdyoutada"</SPAN><SPAN class="punctuation token">)</SPAN>
addLayer <SPAN class="operator token">=</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>mapping<SPAN class="punctuation token">.</SPAN>Layer<SPAN class="punctuation token">(</SPAN><SPAN class="string token">'test4'</SPAN><SPAN class="punctuation token">)</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>mapping<SPAN class="punctuation token">.</SPAN>AddLayer<SPAN class="punctuation token">(</SPAN>df<SPAN class="punctuation token">,</SPAN> addLayer<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"AUTO_ARRANGE"</SPAN><SPAN class="punctuation token">)</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>AddMessage<SPAN class="punctuation token">(</SPAN><SPAN class="string token">"Finished Adding raster & applying symbology."</SPAN><SPAN class="punctuation token">)</SPAN>
mxd<SPAN class="punctuation token">.</SPAN>save<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">del</SPAN> mxd<SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
Thanks!
