I stumbled across this web experience in the ESRI gallery and wondering how the creator made the window that appears once you select "Mehr Infos" (see attached images). I am creating an app with a similar look adn feel. Is this an anchored window? Can this be accomplished without access to developer tools?
No contact info listed for the owner of this experience, so any advice would be greatly appreciated.
https://experience.arcgis.com/experience/2f4ec127f2444df9af494fddadcb3d88
It is a button widget, which opens another view in the section widget. The list widget is the first view in the section. This is all done online without any developer tools.
Cheers,
David
I agree.Create a section widget and within that item insert a list connected to the data as View 1. When an item from the list is selected, or the button is clicked, the link is made to a second view, View 2, which holds a connected text and image card with the details you wish to include in "more info", then simply set a "back" button linking to View 1.
Thank you both! Greatly appreciated.
@JonathanMcDougall @DavidMartinez
Hi, question if you guys don't mind, how did this person have separate list templates for mobile and desktop? I noticed when you go to the mobile version of the application the list scrolls horizontally and vertically on the desktop. When I try to do the same style, Experience Builder forces my list template to be the same for both mobile and desktop.
@JohnPaulAlbana
So, when you switch to different base devices ExpB will set a default "Auto" layout setting - I find switching to custom and then, if you have the patience, create a new app by manipulating the visible widgets etc. You can almost create three very unique applications.
Hello David,
How can we set the button widget to go to different views? For example, in the web experience mentioned on this post, a user can go thru the list and every time you click on the 'more info' button it looks like it takes you to a different view.
I added a list widget to my web experience with the button widget. When I set the link in the button widget, the view I selected as my link gets applied to all of the buttons on my list items. Is there a way to have each button go to a different view?
Eric
