Good morning,
Recent versions of Survey123 Connect do not allow anymore to have duplicate names in a choice list - duplicates were allowed in previous versions of Survey123Connect. Could it please be reinstated?
My use cases are in forestry management, where Survey123 is used to identify, locate & describe trees.
Just as most other types of wildlife species, tree species hav:
- a single scientific (latin) name in our database,
- potentially several vernacular names (because vernacular names differ from a region to another, or from a foresters' generation to another).
I attach an example mini-survey illustrating the case, with the following parameters:
The result of that mini survey is illustrated below: two entries for the Oak are missing, only the first label from the choices list appears in Survey123 :
I did interact with the "allow_choice_duplicates" parameter in the seetings tab, with no effect (per ref. here: https://github.com/XLSForm/xlsform.github.io/blob/master/_sections/home-english.md).
Many thanks in advance!
With kind regards,
Hélène.
