https://community.esri.com/t5/arcgis-pro-questions/exporting-to-pdf-from-arcgis-pro-is-producing-large-file-sizes/m-p/119596#M4922
PDF file sizes exported from ArcGIS Pro are HUGE compared to ArcMap. There is no need for this. I understand why https://support.esri.com/en/technical-article/000022153 and this is solving a problem that we didn't have.
The PDFs exported from ArcMap were just fine, printed great. We have remote workers that can't even OPEN a pdf on VPN that was exported at 300 dpi from ArcGIS Pro.
I know the work arounds too. Buy Adobe - save as reduced file size. Use Adobe print to PDF. This should be solved in ArcGIS Pro!
Thanks.
The size of the output PDF depends very much upon the layers in the map and the other export settings, not just the DPI. I have tabloid (11 x 17) PDFs that export at under 1MB @ 300 DPI, and letter-sized maps that export at closer to 5 MB at < 150 DPI.
Andrea,
We've made lots of changes in the recent releases to help users with this problem, but one that was added a few releases ago is "output as image".
If your map contains lots of vector data, you might get better filesizes by using the "output as image" option in ArcGIS Pro, which will force flattening of vector layers similar to the "optimize pdf" option in Adobe Acrobat.
lastly we fixed an outstanding issue regarding masking layers causing bloat in filesize in PDF exports in the upcoming 2.8 release (in beta now).
Can you give "output as image" a try and let us know if that resolves the problem for you on a current version of Pro?
Regards,
Jeremy W.
@JeremyWright Thank you. We are on 2.7.0 and between the time I posted this and your response we were able to figure out how to use the "output as image" properly. We can't use the "Adaptive compression" because it looks bad. But if we use the JPEG image compression on Quality almost Max and Compress vector graphics, 300 dpi, Raster resample: Best, with no georeference information exported and no layers and attributes - then we can get a pdf that's similar to what we would expect from ArcMap.
Glad to hear there might be even more progress in 2.8.
Thank you.
@Anonymous User if you could share your project (package it from share tab of ribbon->Project Package) with me so I could evaluate the adaptive compression issue you noted, that would be super awesome. Adaptive attempts to determine the best compression type from the type of image object being compressed - if it looks bad that may mean our heuristic for picking compression type might need to be adjusted. I can DM you separately to work out file transfer details.
In any event I'm glad Export As Image is working OK for you! We'll continue to work on these items during the release following 2.8 as well - I have a few issues already on the plan there too.
@JeremyWright Ok great. Well, I talked to my tech and it looks like in this instance the pdf looked ok but it didn't compress. So the adaptive compression pdf is 13MB whereas the jpeg compression pdf is 2MB. I can send you the project package. DM me and I'll be happy to send it.
I had to upgrade to 2.7.3 just to export the pdfs because of graphic bug BUG-000136364!
(Sorry off topic: My tech also mentioned both 2.7.2 and 2.7.3 have issues with adding items to legends during the export. These items are usually tied to web services add via URL and the best work around right now is to make the items visible in the legend in the layout and create a white rectangle placed over them. - Maybe you're already aware of that.)
I would like to be able to compress PDF maps I create when I need to export them so they can be easily e-mailed yet maintain the sharpness and readability of the PDF. The work around is to create the PDF, open it up in Adobe and use their add-on compression tool ( requires a subscription). It would be handier to do this directly within ArcGIS Pro and bypass Adobe.
For anyone following this idea page: we figured out that "Output as image" rasterizes labels. So the labels look blurry when you print the pdf. So we can't use that.
But I am using ArcGIS Pro 2.8.3 now and our settings are working well:
No output as image
image compression: Adaptive
Quality: 85
Compress Vector graphics
Vector Resolution: 300 dpi
Embed Fonts
Very helpful hint that our GIS Specialist found: And add basemaps to a group and apply transparency to group or the pdf will have grid lines - https://geodesign.studio/export-arcgis-pro-adobe-illustrator/
@Anonymous User I'm glad the improvements we've implemented over the last couple releases are working out for you - several changes were made to improve file size. We have even more improvements going in to the next release of ArcGIS Pro as well.
@BobPlummer can you try the settings Andrea has recommended with the latest release of ArcGIS Pro (currently 2.9.2) and see if these meet your needs?
If you have a specific map or layout that proves particularly hard to get comparable exports on, I'd encourage you to try ArcGIS Pro 3.0 when it is released later this year - we have a few enhancements to export file size reduction that may prove very useful for you.
We use a lot of aerial images in our map and using "output as image" makes the PDF blurry. I have 2.8
I'd just like to take a moment (while Adobe continues to try to open my exported map) to add my voice to this frustration. ArcMap worked so nicely, we didn't even know how good we had it. I have been trying various configurations over the course of the last two days, to try to export a big map book (99 pages at 11" x 17", with a lot of layers).
My initial export attempt resulted in a 3,558,818 KB file (yes, that's 3.55 GB).
There are too many layers to practically make 'generalized' copies of them. Most of my PDF outputs have been so big that Adobe cannot open them...occasionally I get an error from Adobe about 'damaged file'...'being repaired' but it just hangs until I have to use Windows to 'End Task'.
My current strategy is to export my map pages in 20-page chunks, then try to reduce the file size and combine them all in Adobe at the the end...not my ideal work-around.
@anonymous User
Thank you for posting the Helpful Settings. I was attempting to export a single large layout that included satellite imagery for a colleague, but my own option selection was resulting in ...oddities (blurriness and ever-expanding file sizes). The settings you provided resulted in the smallest file size I'd seen all day, without any 'value-added blurriness.'
Slainte mhath! 🦆
Sign in to post, follow content, and more. New here? Register for free.
