I am building a survey in Survey123 Connect. I have it just about right except one thing. It seems it should be simple, but I can't figure out how to do this:
A user is asked for their mailing address. Then they are asked if their property address is the same as their mailing address. If yes, I want the property address field to auto-populate with the mailing address they just entered. If no, then I have a follow up text box appear where they can enter in their property address (which is the same field the auto-populate would write to if they had said yes).
I have the second part set up correctly, but I can't figure out how to do the former (auto-populate from the mailing address field).
Is this possible?
Survey is here: https://survey123.arcgis.com/share/242bfa0476af4548bb6a0296f4e54abc
