We are just trying to install ArcGIS for AutoCAD on a machine with Autocad 208/19/20 installed on it.
But the install fails with: Required Autodesk AutoCAD.
Any ideas on how to resolve this would be appreciated.
Hi! We support AutoCAD versions 2017 and up so your set up should not be an issue. Can you check to see if you have the following folder C:\Program Files\Autodesk\ApplicationPlugins ?If not you will have to recreate that folder manually or reinstall AutoCAD as this is the folder ArcGIS for AutoCAD installs into.
I was having the same issue installing AutoCAD for ArcGIS 400.2 with AutoCAD 2019 installed. Previously Version 370 installed without any issues. I created the folder that @Randy_Garcia mentioned, then 400.2 installed just fine, and the ArcGIS ribbon loaded in AutoCAD. Thanks!
Dear @JonathanDandois I’m really stressed because I can’t find a solution to this problem
I have installed two times autocad and I have also reached those folder
Do you have any ideas for another solution? thank you very much
Hi @MicheleInserra , I just had occasion to uninstall AutoCAD (2022) and ArcGIS for AutoCAD (410) and reinstall both and everything installed correctly for me. I am not sure if that is an option for you.
