I am having trouble adding raster output to the runtime map.
I am running the GPK from the vehicle commander sample to create a raster viewshed (Local Geoprocessor).
This GPK returns a GPRasterData parameter which has a URL to a TIF file.
I then download the TIF file to a temporary location and then using the Add shapefiles and raster data sample I add it to the map. The problem is that the local server is not reading the TIF file correctly and errors out. It appears to open a stream of only ~125 bytes when the tif is ~33k.
I am on 10.2.2 of Runtime.
Is there a better way of taking a Raster output from a gpk and adding it to the map?
The GPK appears to work fine in ArcDesktop 10.2.
The java samples seem to be a bit easier as there are methods that allow you to directly get a layer from the result.
