Looking at the results from ArcGIS Earth's interactive tool set, specifically the Viewshed. Left confused.
We run Viewshed models frequently within Pro, sourced from a variety of Lidar. As you would expect, we get a fairly robust DSM from the lidar which allows us to see the way trees, structures etc will effect the view towards a tower, for example.
Looking at this tool in Earth, I am seeing that the input surface service is an ESRI surface https://elevation3d.arcgis.com/arcgis/rest/services/WorldElevation3D/Terrain3D/ImageServer
Unless I'm mistaken(most likely the case!!), this would only provide a ground surface value and not anything above the ground? And if that is a correct statement, then I'm confused as to how the Viewshed example in this document https://doc.arcgis.com/en/arcgis-earth/use/interactive-analysis.htm is able to provide a result which seems to include the features above the ground in the analysis.
Anyone able to help clarify this for me?
