Hi, I have an esri sample code attached -- I successfully inserted my basemap but when I tried to add my mapservice, it doesn't error out but it doesn't show the mapservice. Any suggestions on what I'm missing in the code? Thank you.
Thank you for the information. I made the modification and then it errored out on something else. So I started from beginning modifying the original esri sample code which I attached initially. (Sorry, I'm new to this and I don't see an option to use the "Insert/Edit code sample" button so I'm pasting it here.) The basemap is good but the annexation map service is not displaying. Any suggestion is appreciated. Thank you.
map = new Map("mapDiv", {// basemap: "streets",center: [-85.82966, 33.666494],zoom: 7});var baseMapLayer = new esri.layers.ArcGISTiledMapServiceLayer("https://gismaps/arcgis/rest/services/Basemap/StreetBaseMap/MapServer");map.addLayer(baseMapLayer);
map.on("load", initToolbar);var featureLayer1 = new FeatureLayer("https://gismaps/arcgis/rest/services/CountyServices/Annexations/MapServer/0", {mode: FeatureLayer.MODE_SELECTION,infoTemplate: new InfoTemplate("Case Name: ${CaseName}", "${*}"),outFields: ["NumParcels"]});
map.addLayers([featureLayer1, featureLayer2, featureLayer3]);
Ken, thank you for the information. I made the modification fine but it's erroring out on something else so I started from beginning. (Sorry, I'm new to this and I don't see an option to use the "Insert/Edit code sample" button so I will paste it here.) This is the original esri sample code and I added my basemap fine. But when I add my annexation map service, it doesn't display. Thank you for any suggestions you can provide.
var map, tb;
require(["esri/map", "esri/toolbars/draw", "dojo/promise/all","esri/symbols/SimpleMarkerSymbol", "esri/symbols/SimpleLineSymbol", "esri/symbols/SimpleFillSymbol","esri/symbols/PictureFillSymbol", "esri/symbols/CartographicLineSymbol", "esri/layers/FeatureLayer","esri/graphic", "esri/tasks/query", "esri/tasks/QueryTask", "esri/InfoTemplate","esri/Color", "dojo/dom", "dojo/on", "dojo/parser", "dijit/layout/BorderContainer", "dijit/layout/ContentPane","dijit/layout/AccordionContainer", "dojo/domReady!"], function (Map, Draw, All,SimpleMarkerSymbol, SimpleLineSymbol, SimpleFillSymbol,PictureFillSymbol, CartographicLineSymbol, FeatureLayer,Graphic, Query, QueryTask, InfoTemplate,Color, dom, on, parser) {
parser.parse();
map = new Map("mapDiv", {// basemap: "streets",center: [-85.82966, 33.666494],zoom: 7});var baseMapLayer = new esri.layers.ArcGISTiledMapServiceLayer("https://gismaps.fultoncountyga.gov/arcgispub2/rest/services/Basemap/FultonStreetBaseMap/MapServer");map.addLayer(baseMapLayer);
map.on("load", initToolbar);var featureLayer1 = new FeatureLayer("https://gismaps.fultoncountyga.gov/arcgispub/rest/services/CountyServices/Annexations/MapServer/0", {mode: FeatureLayer.MODE_SELECTION,infoTemplate: new InfoTemplate("Case Name: ${CaseName}", "${*}"),outFields: ["NumParcels"]});
// var featureLayer1 = new FeatureLayer("http://sampleserver6.arcgisonline.com/arcgis/rest/services/Census/MapServer/0", {// mode: FeatureLayer.MODE_SELECTION,// infoTemplate: new InfoTemplate("Block: ${BLOCK}", "${*}"),// outFields: ["POP2000", "HOUSEHOLDS", "HSE_UNITS", "TRACT", "BLOCK"]// });
var featureLayer2 = new FeatureLayer("https://gismaps.fultoncountyga.gov/arcgispub/rest/services/Temp/ParcelDownload_test/FeatureServer", {mode: FeatureLayer.MODE_SELECTION,infoTemplate: new InfoTemplate("Block Group: ${BLKGRP}", "${*}"),outFields: ["POP2000", "HOUSEHOLDS", "HSE_UNITS", "TRACT", "BLKGRP"]});
var featureLayer3 = new FeatureLayer("http://sampleserver6.arcgisonline.com/arcgis/rest/services/Census/MapServer/2", {mode: FeatureLayer.MODE_SELECTION,infoTemplate: new InfoTemplate("County Name: ${NAME}", "${*}"),outFields: ["POP2000", "HOUSEHOLDS", "HSE_UNITS", "NAME"]});
// markerSymbol is used for point and multipoint, see http://raphaeljs.com/icons/#talkq for more examplesvar markerSymbol = new SimpleMarkerSymbol();markerSymbol.setPath("M16,4.938c-7.732,0-14,4.701-14,10.5c0,1.981,0.741,3.833,2.016,5.414L2,25.272l5.613-1.44c2.339,1.316,5.237,2.106,8.387,2.106c7.732,0,14-4.701,14-10.5S23.732,4.938,16,4.938zM16.868,21.375h-1.969v-1.889h1.969V21.375zM16.772,18.094h-1.777l-0.176-8.083h2.113L16.772,18.094z");markerSymbol.setColor(new Color("#00FFFF"));
// lineSymbol used for freehand polyline, polyline and line.var lineSymbol = new CartographicLineSymbol(CartographicLineSymbol.STYLE_SOLID,new Color([255, 0, 0]), 10,CartographicLineSymbol.CAP_ROUND,CartographicLineSymbol.JOIN_MITER, 5);
// fill symbol used for extent, polygon and freehand polygonvar fillSymbol = new SimpleFillSymbol();
function initToolbar() {tb = new Draw(map);tb.on("draw-end", addGraphic);
// event delegation so a click handler is not// needed for each individual buttonon(dom.byId("info"), "click", function (evt) {if (evt.target.id === "info") {return;}var tool = evt.target.id.toLowerCase();map.disableMapNavigation();tb.activate(tool);});}
function addGraphic(evt) {//deactivate the toolbar and clear existing graphicstb.deactivate();map.enableMapNavigation();
// figure out which symbol to usevar symbol;if (evt.geometry.type === "point" || evt.geometry.type === "multipoint") {symbol = markerSymbol;} else if (evt.geometry.type === "line" || evt.geometry.type === "polyline") {symbol = lineSymbol;} else {symbol = fillSymbol;}
map.graphics.add(new Graphic(evt.geometry, symbol));queryMapService(evt.geometry);}
function queryMapService(Geom) {var promises = [];
var query = new Query();query.returnGeometry = false;query.outFields = ["*"];query.geometry = Geom;promises.push(featureLayer1.selectFeatures(query, FeatureLayer.SELECTION_NEW));promises.push(featureLayer2.selectFeatures(query, FeatureLayer.SELECTION_NEW));promises.push(featureLayer3.selectFeatures(query, FeatureLayer.SELECTION_NEW));var allPromises = new All(promises);allPromises.then(function (r) {showResults(r);});}
function showResults(results) {var resultCount = results.length;console.log(resultCount);}});
When adding code, use the "Insert/Edit code sample" button instead of adding it as an attachment.
The first thing I see is that the require modules don't match up with the function arguments
require(["esri/map", "esri/toolbars/draw", "dojo/promise/all", "esri/symbols/SimpleMarkerSymbol", "esri/symbols/SimpleLineSymbol", "esri/symbols/SimpleFillSymbol", "esri/symbols/PictureFillSymbol", "esri/symbols/CartographicLineSymbol", "esri/layers/FeatureLayer", "esri/graphic", "esri/tasks/query", "esri/tasks/QueryTask", "esri/InfoTemplate", "esri/Color", "dojo/dom", "dojo/on", "dojo/parser", "dijit/layout/BorderContainer", "dijit/layout/ContentPane", "dijit/layout/AccordionContainer", "dojo/domReady!"], function ( Map, Draw, All, SimpleMarkerSymbol, SimpleLineSymbol, SimpleFillSymbol, PictureFillSymbol, CartographicLineSymbol, FeatureLayer, Graphic, Query, QueryTask, InfoTemplate, Color, dom, on, parser, ArcGISDynamicMapServiceLayer) {
You haven't included the module for ArcGISDynamicMapServiceLayer.
